My small 96 Blazer build
#731
#732
I'm not sure what fuse box I will use yet. Probably something with 8-10 fuses so I can add additional accessories as needed in the future. Heck I may go and pull one from a random car at the yard who knows lol!
I did add some cheap top post mounts with studs on them today and wired up the winch along with transferring all of my other wires to the top post accept the factory starter and ground wires. Went out in the woods and did a full pull with the winch just to set the line and everything worked perfectly
. I had a large drop in volts which is I be expected but no drop in engine rpm while doing a constant 90ft or so pull so I think all is well with the setup
. Now I just need to find a way to get stuck or better yet get someone else stuck so I have an excuse to use it!!
![Smile](https://blazerforum.com/forum/images/smilies/smile.gif)
#733
Sounds good Rex. Quick update on mine, one side is done...
![](https://blazerforum.com/forum/attachments/builds-48/18149-my-small-96-blazer-build-ll4h.jpg?dateline=1383015243)
and put on the winter wheels and tires,
![](https://blazerforum.com/forum/attachments/builds-48/18150-my-small-96-blazer-build-15q6.jpg?dateline=1383015243)
#734
That looks good how you finished it up and blended it in!
#735
#736
Looks awesome, hopefully I can make some when I build my new front bumper over my thanks giving vacation (taking a week off of work). Any movement out of them when you jack up the truck off of them?
#737
Time is the hard part! I could knock a set out in a day if I had no interruptions and everything I needed there already. I couldn't see any movement at all even without the block of on the jack and only having 6 of the 12 bolts installed.
#738
looks good man...nicely done.
#739
Thank you sir!
#740
