Resto/mod 1999 Trailblazer
Old Apr 7, 2021 | 02:15 AM
  #51
Mods's Avatar
Found yet another leak, and a reason as to why not to buy DORMAN anymore, PCV L-boot split down the seamline, only a few hours of runtime since installing them... patched it with some 3/8th vinyl tube for right now until i can order a proper replacement. also have all of the parts for the vacuum system redo, and found washout on the intake runners around the #3 injector, so i guess that spider is my fuel pressure loss source.
Old Apr 7, 2021 | 07:01 AM
  #52
Mods's Avatar
got better video of the exhaust note, and, is this amount of valve clatter normal for an engine that's been shelved a couple of times over the years?
Old Apr 12, 2021 | 12:52 AM
  #53
Mods's Avatar
Will be doing replacement of the intake hat seal. if you dont want to do the old method of using a fuel pump tank seal and a drum sander i'll post P/Ns/ring sizes. o-rings get here from McMaster Carr on tuesday.
Old Apr 17, 2021 | 11:22 PM
  #54
Mods's Avatar
and of course, hit a snag with the intake seal
throttle body crosssection at inlet is 78mm,
throttle body intake OD is, dont know but alot bigger
stretched a 5mm/thick 78mm ID ring around it and cranked the hat down, seals well enough but it could be so much better.
Also replaced the transfer case output shaft/driveshaft yoke seal and found brownish/reddish fluid, not ATF though, tastes like gear oil so someone did a ****y when the Tcase was out of the rig a while back before it was my project.
Old Apr 18, 2021 | 07:02 AM
  #55
Tastes like gear oil?
Old Apr 19, 2021 | 12:33 AM
  #56
Mods's Avatar
..dont ask. and dont put your head under the Tcase while speaking to people while removing the rear tailshaft yoke seal.
Old Apr 19, 2021 | 04:03 PM
  #57
eshaw's Avatar
Ha ha ha, yummy!
Old Apr 22, 2021 | 06:38 PM
  #58
Mods's Avatar
Looking alot like a barn pull with all that dust on the roof. really need to get this thing to a weld shop to fix the hinge pin holes so i can if anything wash it.
Old May 9, 2021 | 04:51 AM
  #59
I had to come back and check on the wipers!!
Old May 12, 2021 | 09:16 PM
  #60
Mods's Avatar
Lol, Yeah i wasnt kidding, it looks weirdly clean but i like the look of weird metal bits all over the thing so i plan on replacing the wiper motor soon and repainting the arms.
for right now tho
