Detailing Discuss detailing your Blazer within.
Rear Body Pillar question
Old 02-09-2009, 02:39 AM
Bigringtravis's Avatar
Bigringtravis is on a distinguished road
Default Rear Body Pillar question
So I`ve read on here a few times about that Black part on the truck next to the rear glass that discolors/fades and wondered this... What about using the Truck bed coating to give it that `thick Plastic Look` again? I`ve got the spray and I'm just curious, once we get a day above 65*, how this will work.
Has anyone else tried this? Since mine is a 1995, it`s discolored pretty badly.
It`s the only ugly thing left on the truck!
Old 02-09-2009, 08:06 AM
WolfPack's Avatar
Default RE: Rear Body Pillar question
You should do the tire carrier and the pillars in bed liner[8D]
Old 02-09-2009, 11:41 AM
football8686's Avatar
football8686 is an unknown quantity at this point
I had the same problem on my 2000 2 dr. Minelooked identical to yours. One solution I tried was sanding off the rough plastic to smooth it some. Then I masked it off and sprayed on a couple coats of a spray paint designed for plastics. It turned out ok and it looks tons better then before.
Old 02-23-2009, 03:05 PM
stevo's Avatar
stevo is an unknown quantity at this point
post pics when its done, i am starting to see the gloss on mine wearing away
Old 02-26-2009, 11:53 AM
ORIGINAL: stevo
I sure will... I`m waiting for the days to get warmer and a little less breezy! Oh and it should be noted that I do actually have a proper matching spare tire too... They wouldn't remount the original tire as it was from 1995!
Old 03-04-2009, 03:56 PM
oisinirish's Avatar
Wonder if your solutions would work on the removable tops of a K5?
Old 03-04-2009, 03:58 PM
It is a matter of plastic vs. fiberglass. The tops on the K5's were fiberglass with a top coat.
ryankinder82
02-24-2010 02:12 PM
Ugly_Monkey
02-15-2009 09:56 PM
RockingRobin69
01-20-2009 07:55 AM
getonerd
04-08-2008 06:39 AM
Johnkoch
01-06-2008 03:46 PM
Quick Reply: Rear Body Pillar question
