from automatic to manual
Old Jul 19, 2011 | 04:27 PM
stlwaco's Avatar
stlwaco is on a distinguished road
GM stopped making the clutch master?
Old Jul 21, 2011 | 06:26 AM
SoullessNihilist's Avatar
SoullessNihilist is on a distinguished road
no, they just spopped making the hydraulic line.
Old Jul 21, 2011 | 01:45 PM
stlwaco's Avatar
oh ok.
Old Jul 22, 2011 | 09:22 AM
so... the russell parts work perfectly. but i've never done a clutch before and it dosnt want to release all the way. and i wanted to know this: i took the flywheel off of a 89 ct1500 with a 4.3 in it. according to the hollander system on my computer at work it's supposed to be the same, there was a spacer behind the flywheel.( like 1/16 or 1/8 of an inch) i used it on my blazer. and now i'm wondering if that is why my clutch will not release all of the way???? or do i just have to wear it down a little???
Old Jul 22, 2011 | 09:49 AM
If anything, I would think a spacer would cause the clutch to not fully engage.
These clutches are a pain to get all of the air out. I bet there is air in there that is preventing the clutch from fully disengaging.
Old Jul 22, 2011 | 12:34 PM
i said fu$# it and burnt it for a few minutes on a hill, now it works fine!
Old Jul 26, 2011 | 06:16 PM
i've run into a little problem. i called a dealership today about flashing my engine computer to get rid off all the dtc's for the automatic tranny. the guy said i needed the wiring harness from a 5speed. i know theres a way to get around this... but i need a clear large image of the pcm wiring. so i can disconnect all of the unnessessary wiring.
Old Aug 11, 2011 | 01:41 PM
i have almost everything squared away with my blazer, she drives good, except for one problem.. i've called a few garages and dealerships about reprograming my ECM but everyone seems to be uneducated in the matter or says they cant do it, or it might not work. i dont want to spend the money for nothing. does anybody know for sure where i could get this done? and if i'll need a VIN number from a 5speed blazer? again.. i work at a boneyard and my computer gives ,e the same part number for auto and manual.
Old Aug 11, 2011 | 01:58 PM
warthogdriver's Avatar
this may help you out
PCMperformance Programming
or this option
garciamode
Aug 14, 2010 11:05 PM
old skool luvr
Nov 28, 2009 10:18 PM
trhull
Sep 6, 2009 10:49 PM
dew88
Jul 8, 2009 07:35 PM
p_j_robertson
Jul 5, 2006 06:17 AM
