Worth repairing our Blazer???
#21
by any chance was it lowered at any point? I don't see why someone would go through all the trouble to weld that like that, because the front differential and axle supposed to be held on by just a few bolts to brackets
#22
I cant see why the hell someone would weld that????????? The diff has like 2 bolts on each end for where it mounts to the frame and then I think like 1 or 2 more that go through the ears on the diff.
Honestly bro it sounds like your truck is more of just a daily driver, do you even use your 4x4? If I was in your shoes i would just pull the diff out and the front driveline and roll it as a 2wd truck. It will save you an *** load of money. The 4x4 is not something that is "needed" for the truck to function correctly its just an addition that comes in handy. Get what Im saying?
#23
yea I agree if you don't go offroad or drive in the snow I would just say screw the 4wd and pull the whole front diff out
#24
yeah ..... I am betting he is near Duluth MN because he said something about going over the bumps in Duluth MN.
ditch the sway bar
SAS (straight axle swap) with a high pinion D30 from a Jeep and coilovers.
and half a day with some buddies to fix the coolant leak.
ditch the sway bar
#25
duluth huh.......thought i was the only one this far north in mn =P
#26
there is no possible way the front dif bolt r rubbing the bell housing do you mean transfer-case and why would they have to make a new bracket you should be ale to find one at a junk yard or ask around the forum hell i probably have one but I'm not sure what your looking for . it sound like you need a second opinion good luck.
phillymick
11-09-2008 07:54 PM
