Rmoving load from leaf springs for shackles
Old May 20, 2011 | 12:26 PM
1998LT's Avatar
1998LT is on a distinguished road
Default Rmoving load from leaf springs for shackles
I am installing shackles later on today and I was wondering once you pull the bolts from the leaf spring will it violently sting loose if it is on jackstands? Or do I need to remove load from the rear suspension?
Old May 20, 2011 | 01:32 PM
RangerG's Avatar
You can always use some clamps to keep the leafs together. I hear they are a real pain to get back together once they come apart.
Old May 20, 2011 | 02:54 PM
mdehoogh's Avatar
The springs shouldn't move at all. Make sure that your jackstands are supporting the frame and not the axle. If they're under the axle, then the weight of the truck is still on the springs/rear-end.
Also make sure you have the truck high enough in the air. You've got to jack it up high enough so that the rear suspension can extend all the way down and still have room to add in lift shackles. With the jackstands under the frame, I still had my truck up high enough so there were about 3-4" of space between the tires and the ground
Here's a pic from when I installed mine. After removing the lower bolt, you can see how the spring only shifted up about 1/4"
I have more pics in this thread https://blazerforum.com/forum/tech-a...llation-54550/
And there's another really great write-up here https://blazerforum.com/forum/articl...-thread-43925/
Good luck!
02Goldie_Loks
Sep 11, 2015 05:47 PM
btmbass
Lifting Tech
Sep 20, 2011 07:57 PM
step66
Jan 18, 2011 05:31 PM
S10Blazerdude
Lowering Tech
May 1, 2010 07:56 PM
4lowlife
Suspension Tech
Mar 8, 2006 03:53 PM
