Shackles on sagging leaf springs?
Old Jul 28, 2011 | 12:16 AM
btmbass's Avatar
btmbass is on a distinguished road
Default Shackles on sagging leaf springs?
Hey everyone,
I'm pretty set on getting a pair of 2" shackles. My question is if my leaf springs are pretty much flat should I consider replacing them before installing shackles?
Any recommendations on shackles would be appreciated as well.
Old Sep 20, 2011 | 07:22 PM
1997 Gmc Jimmy's Avatar
1997 Gmc Jimmy is on a distinguished road
i know that your pretty set on shakles but if your leaf springs are worn out you can get a good set of add a leafs for like 86 bucks and it would raise you up like 2" in the rear but it would make your ride a bit stiffer but if you ever pull anything you'd be set
Old Sep 20, 2011 | 07:31 PM
btmbass's Avatar
Is it hard to find replacement leaf springs?
Old Sep 20, 2011 | 07:43 PM
coolasice's Avatar
coolasice will become famous soon enough
no, lmctruck has them as well as other suspension places, the add a leaf is cheapest as a new set of springs will run you $300 easy plus shipping..
I had a broken leaf and got a set of ok ones from the yard, they're still kinda worn out but they work fine for me and all in cost me under $180 with new bushings and bolts....
Old Sep 20, 2011 | 07:49 PM
btmbass's Avatar
If I get an add a leaf and install the fabtech shackles I already have the truck would look pretty raked, even with a Tbar crank right?
Old Sep 20, 2011 | 07:57 PM
i found some SkyJacker add-a-leaf for $87 that will make up for sagging and lift it like 2"
02Goldie_Loks
Sep 11, 2015 05:47 PM
1998LT
Lifting Tech
May 20, 2011 02:54 PM
S10Blazerdude
Lowering Tech
May 1, 2010 07:56 PM
trustyrusty
Nov 26, 2009 05:45 AM
Blindthieves
Suspension Tech
Mar 6, 2007 12:41 AM
