Rmoving load from leaf springs for shackles
I am installing shackles later on today and I was wondering once you pull the bolts from the leaf spring will it violently sting loose if it is on jackstands? Or do I need to remove load from the rear suspension?
Also make sure you have the truck high enough in the air. You've got to jack it up high enough so that the rear suspension can extend all the way down and still have room to add in lift shackles. With the jackstands under the frame, I still had my truck up high enough so there were about 3-4" of space between the tires and the ground
Here's a pic from when I installed mine. After removing the lower bolt, you can see how the spring only shifted up about 1/4"
I have more pics in this thread https://blazerforum.com/forum/tech-a...llation-54550/
And there's another really great write-up here https://blazerforum.com/forum/articl...-thread-43925/
Good luck!
02Goldie_Loks
Sep 11, 2015 05:47 PM
