Changed all interior lights to LEDs.DIRECT REPLACEMENT.
#31
RE: Changed all interior lights to LEDs.DIRECT REPLACEMENT.
I can't remember what bulb number it is for those...
But it should either just pull out, or you'll have to push in and twist for it to come loose...
#32
Alright, because I was twisting it normally and it didn't budge. Can't even get a good look at the way the bulb is in from the angle, but I gotta try again. And the dome lights are the same? Just pop them out?
#33
What I did with the ones in the footwell, was to take all that plastic down and then actually took the housing down that holds the light. If I recall correctly you just have to pull it out. They are real stubburon though. Good luck.
#34
The dome lights, you should be able to see once you get the lens off... Unless you mean the map/console lights, in which case, I can't help, because I don't have those, lol.
If the foot well bulbs are 168s then they just pull out... They SHOULD be in a 2nd gen... the 1st gen are the old school push & twist style...
#35
yep the 168's are the same base as a 194, which is more common in LED bulbs. The maplights in the newer gen 2 trucks are easy, just need a 194 bulb pull the old one out and push the new one in and your good to go. Which now that I remember is the exact same way the floor courtesy lights are.
#36
ORIGINAL: lennyblazer
#37
Yeah I was routing some wires under the plastic for my fuzz buster and iPod connector. So I just took down the plastic, then it was easier to see the bulb socket.
Oh and I have decided to order 4 HID White LED's for the maplights and then some new Blue LED's for the courtesy lights (the ones that come on when a door is opened). I'll post up some pics when I get them installed.
#38
Thats sick looking.....
#39
I need to post some pics too. I have 2 red LEDs under the dash, looks awesome, and white LEDs in both dome lights.
The maplights are annoying, you have to sand down the plastic a lot. It took me so long to do one bulb and I didn't even finish it, so I threw the old bulb back in and put it in the truck.
#40
Have been doing this very thing. Thanks for the site that had better prices then what I was buying.
eddy78741
09-19-2013 03:14 AM
