Suspension Tech Have a question about modifying your suspension? Ask it here.
replacement Leaf springs
Old Jun 16, 2012 | 01:13 AM
collinb1234's Avatar
collinb1234 is on a distinguished road
Default replacement Leaf springs
Where online can one buy replacement leaf springs for a 2000 Jimmy, mine are flatter then a level, and are kind of bending the opposite way, I was thinking aal but I might as well buy the whole new spring, it would be cool if I actually found lift springs like a full size. Anyone know where to look?? Thanks
Old Jun 16, 2012 | 02:05 AM
jaked up's Avatar
jaked up is on a distinguished road
i used these in my 98
these are oem leafs
95-05 Blazer / Jimmy / Envoy / Bravada Rear Leaf Spring - TheSuspensionKing.com
and then you will need to put in an add a-leaf
Chevy S-10 Blazer Add-a-Leafs 2" Rear by Tuff Country
Old Jun 19, 2012 | 10:22 AM
Thanks, now with the price of new ones, I might make a bastard pack, I want to find a second leaf and cut about an inch shorter on each side so it will curve out the flattened spring, can I use fullsize springs, or do I have to use s-10 springs?
Old Jun 19, 2012 | 10:33 AM
warthogdriver's Avatar
I did the bastard pack.
My originals were flat...so i went to the yard and got some z85 springs...then took the largest spring from original pack and cut the ends so they where mid point between the one above and below.
Worked great for me.
Old Jun 19, 2012 | 08:29 PM
What all hardware will I need? U bolts, leaf centering pin, leaf clamps?? Can I reuse my stock hardware?? Thanks
Old Jun 20, 2012 | 08:10 AM
its not a good idea to reuse the stock hardware.
i had to replace the u bolts and the center pins.
Old Jun 20, 2012 | 10:06 AM
Ok can I pick up u bolts at carquest or advanced auto / autozone?? And do you know the measurements of the bolts?? Arnt they 3in round??
Or do I need to order online?
Last edited by swartlkk; Jun 20, 2012 at 10:14 AM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond and wait for a response. Rules are rules.
rcravincase
May 13, 2010 08:13 PM
S10Blazerdude
Lowering Tech
May 1, 2010 07:56 PM
alamantia
Suspension Tech
Nov 17, 2006 11:14 AM
tommyd
Suspension Tech
Aug 25, 2006 12:11 AM
4lowlife
Suspension Tech
Mar 8, 2006 03:53 PM
